Kod: Tümünü seç
alias -l yversion { return v6.4 }
alias -l yapi { return AIzaSyBZFSgBuREDKNRwHqvHix68W3WiMyZ3N6c }
menu status,channel,query {
YouTube:youtube
alias YouTube { dialog -m YouTube YouTube }
dialog Youtube {
title "YouTube v6.4"
size -1 -1 242 196
option dbu
icon $mircdirYoutube.ico, 0
link "View Script On Hawkee", 1, 3 2 59 8
button "Exit", 7, 88 181 72 12, cancel
tab "About", 10, 2 9 235 169
link "YouTube Script (Parse Vids and Search) v6.4 -- Post Bugs and Feature Requests Here", 24, 16 26 208 8, tab 10
text "Last updated on June 20 2016", 19, 7 66 95 8, tab 10
text "Please post suggestions, complaints, or bugs on the hawkee link (or in chat)", 20, 7 37 188 8, tab 10
text "!commands will notice the user; @commands will be public to the channel", 13, 7 93 175 8, tab 10
text "Default behavior is to run on every channel for every nick. Use the Nick and Channel Settings Tabs to change it for invidividual channels or nicks.", 65, 7 114 208 14, tab 10
link "Click here to chat (leave a message for nick1)", 66, 58 50 110 8, tab 10
text "Use the Basic Options Tab to adjust which parts of the script will run and basic formatting options.", 23, 7 142 195 13, tab 10
button "Check for Updates", 21, 102 64 54 12, tab 10
tab "Basic Options", 2
box "Search Commands/Options", 60, 7 52 209 29, tab 2
text "youtube <search terms>; ytsearch <search>; ysearch <search terms>", 62, 10 60 175 8, tab 2
box "Disable Options", 5, 7 23 209 27, tab 2
check "Disable Search - Disables search commands below", 11, 11 29 133 10, tab 2 flat
check "Disable Parse - Disables the script from automatically sending info", 14, 11 38 175 10, tab 2 flat
box "Output Options", 9, 7 83 209 93, tab 2
check "Disable Views - Removes 'Views: <Views>'", 15, 11 90 123 10, tab 2
check "Disable Length - Removes 'Length: <Length>'", 16, 11 99 130 10, tab 2
check "Disable User - Removes 'User: <User>'", 17, 11 108 113 10, tab 2
check "Disable Formatting - Removes Colors and Bold", 22, 11 117 127 10, tab 2
edit "", 58, 99 69 15 10, tab 2 limit 1
text "Number of search results displayed:", 25, 10 70 87 8, tab 2
check "Enable Date - Adds 'Uploaded: <Date>'", 57, 11 126 120 10, tab 2
check "Enable Likes - Adds 'Likes: <Likes>", 27, 11 135 130 10, tab 2
check "Enable Dislikes - Adds 'Dislikes: <Dislikes>", 28, 11 144 130 10, tab 2
check "Enable Description - Adds 'Description <Description>", 29, 11 153 139 10, tab 2
check "Enable Notice Mode (Does Not Message Channel)", 30, 11 163 139 10, tab 2
tab "Channel Settings", 3
list 6, 8 56 220 116, tab 3 sort size extsel vsbar
edit "", 8, 9 26 155 25, tab 3 multi autohs autovs
text "List of channels the script will NOT run on", 12, 48 50 101 6, tab 3
button "Add", 4, 190 25 37 12, tab 3
button "Remove", 63, 190 42 37 12, tab 3
button "Click here to enter #channels ...", 64, 10 27 153 23, tab 3
tab "Nick Settings", 26
text "List of nicks the script will NOT run for", 70, 48 50 101 6, tab 26
list 71, 8 56 220 116, tab 26 sort size extsel vsbar
button "Remove", 72, 190 42 37 12, tab 26
button "Add", 73, 190 25 37 12, tab 26
edit "", 69, 9 26 155 25, tab 26 multi autohs autovs
button "Click here to enter Nicks ...", 74, 10 27 153 23, tab 26
text "This script created by nick1", 18, 171 2 66 8
on *:dialog:youtube:init:0: {
FillChannelBox
FillNickBox
$iif(%_youtube.nocolor == true,did -c youtube 22,noop)
did -a youtube 58 $iif(%_youtube.limit == $null,1,%_youtube.limit)
$iif(%_youtube.noviews == true,did -c youtube 15,noop)
$iif(%_youtube.nolength == true,did -c youtube 16,noop)
$iif(%_youtube.nouser == true,did -c youtube 17,noop)
$iif(%_youtube.date == true,did -c youtube 57,noop)
$iif(%_youtube.likes == true,did -c youtube 27,noop)
$iif(%_youtube.dislikes == true,did -c youtube 28,noop)
$iif(%_youtube.description == true,did -c youtube 29,noop)
$iif(%_youtube.notices == true,did -c youtube 30,noop)
$iif($group(#search) != on,did -c youtube 11,noop)
$iif($group(#parse) != on,did -c youtube 14,noop)
alias FillChannelBox {
did -r youtube 6
var %y 1
while (%y <= $numtok(%youtubefetch,44)) {
did -a youtube 6 $gettok(%youtubefetch,%y,44)
inc %y
alias FillNickBox {
did -r youtube 71
var %y 1
while (%y <= $numtok(%nolinks,44)) {
did -a youtube 71 $gettok(%nolinks,%y,44)
inc %y
on *:dialog:youtube:edit:58: {
if (($did(58).text < 1) || ($did(58).text !isnum) && ($did(58).text != $null)) {
did -r youtube 58
noop $input(Enter a number between 1 and 9, owd, Invalid input!)
elseif ($did(58).text != $null) { set %_youtube.limit $did(58).text }
on *:dialog:youtube:sclick:*: {
if (($did == 1) || ($did == 24)) { run http://hawkee.com/snippet/8577/ }
elseif ($did == 66) { server -m irc.rizon.net:6667 -jn #rsbot_help }
elseif ($did == 22) { set %_youtube.nocolor $iif($did(22).state,true,false) }
elseif ($did == 15) { set %_youtube.noviews $iif($did(15).state,true,false) }
elseif ($did == 16) { set %_youtube.nolength $iif($did(16).state,true,false) }
elseif ($did == 17) { set %_youtube.nouser $iif($did(17).state,true,false) }
elseif ($did == 57) { set %_youtube.date $iif($did(57).state,true,false) }
elseif ($did == 27) { set %_youtube.likes $iif($did(27).state,true,false) }
elseif ($did == 28) { set %_youtube.dislikes $iif($did(28).state,true,false) }
elseif ($did == 29) { set %_youtube.description $iif($did(29).state,true,false) }
elseif ($did == 30) { set %_youtube.notices $iif($did(30).state,true,false) }
elseif ($did == 11) { $iif($group(#search) == on,.disable,.enable) #search }
elseif ($did == 21) { yupdate }
elseif ($did == 14) { $iif($group(#parse) == on,.disable,.enable) #parse }
elseif ($did == 4) {
set %youtubefetch $addtok(%youtubefetch,$iif(($left($did(8),1) == $chr(35)),$did(8),$+($chr(35),$did(8))),44)
did -r youtube 8
FillChannelBox
elseif ($did == 73) {
set %nolinks $addtok(%nolinks,$did(69),44)
did -r youtube 69
FillNickBox
elseif ($did == 63) {
if ($did(8) != $null) {
set %youtubefetch $remtok(%youtubefetch,$iif(($left($did(8),1) == $chr(35)),$did(8),$+($chr(35),$did(8))),44)
did -r youtube 8
if ($did(6).seltext != $null) { set %youtubefetch $remtok(%youtubefetch,$did(6).seltext,44) }
FillChannelBox
elseif ($did == 3) { did -t youtube 4 }
elseif ($did == 26) { did -t youtube 73 }
elseif ($did == 72) {
if ($did(69) != $null) {
set %nolinks $remtok(%nolinks,$did(69),44)
did -r youtube 69
if ($did(71).seltext != $null) { set %nolinks $remtok(%nolinks,$did(71).seltext,44) }
FillNickBox
raw 408:*: msg $2 $remove($strip($13-),$chr(9),$chr(8))
alias urlencode { return $replacex($regsubex($$1-,/([^\w\s])/Sg,$+(%,$base($asc(\t),10,16,2))),$chr(32),+,$chr(43),%2B) }
on $*:text:/^[!@](disableyt|offyt|disableyoutube|offyoutube)(\s|$)/Si:?: {
if ($2) {
if ($me ison $2) {
if ($nick isop $2) {
msg $nick 4Youtube has been10 disabled on $+(,$2,)
set %youtubefetch $addtok(%youtubefetch,$2,44)
else { msg $nick 4Sorry, you must be an10 op of $+(,$2,) to disable youtube there }
else { msg $nick 4Sorry, I am not10 currently in $+(,$2,) }
elseif ($2 == $null) { msg $nick 4Incorrect Syntax - Use10 $1 <#channel> }
on $*:text:/^[!@](enableyt|onyt|enableyoutube|onyoutube)(\s|$)/Si:?: {
if ($2) {
if ($me ison $2) {
msg $nick 4Youtube has been10 enabled on $+(,$2,)
set %youtubefetch $remtok(%youtubefetch,$2,44)
else { msg $nick 4Sorry, you must be an10 op of $+(,$2,) to enable youtube there }
#search on
on $*:text:/^[!@]y(outube|t|tsearch|search|ousearch|outubesearch)(\s|$)/Si:*: {
$iif($istok(%youtubefetch,$chan,44),halt,noop)
$iif($istok(%nolinks,$nick,44),halt,noop)
if ($($+(%,botflood.,$nick),2)) {
if ($($+(%,botflood.,$nick),2) >= 50) {
ignore -u60 $address($nick,2)
msg $chan $+($nick,$chr(44)) You have been put on ignore for 60secs for abusing the bot.
halt
elseif ($($+(%,botflood.,$nick),2) >= 40) {
msg $chan $+($nick,$chr(44)) Please do not flood the bot.
inc -z $+(%,botflood.,$nick) 20
halt
else { inc -z $+(%,botflood.,$nick) 25 }
var %ticks $ticks
if ($2) {
if ($chan) {
if (($left($strip($1),1) == @) && (%_youtube.notices != true)) { set $+(%,youtube.,%ticks,.msgtype) msg $chan }
else { set $+(%,youtube.,%ticks,.msgtype) notice $nick }
else { set $+(%,youtube.,%ticks,.msgtype) msg $nick }
set $+(%,youtube.,%ticks,.search) $2-
set $+(%,youtube.,%ticks,.query) $urlencode($2-)
sockopen -e $+(youtube.,%ticks) www.googleapis.com 443
notice $nick 4Incorrect Syntax - Use10 $1 <search term>
on *:input:*:{
$iif($istok(%nolinks,$active,44),return,noop)
$iif($istok(%youtubefetch,$active,44),return,noop)
var %ticks $ticks
if (($remove($1,$left($strip($1),1)) == ysearch) || ($remove($1,$left($strip($1),1)) == ytsearch) || ($remove($1,$left($strip($1),1)) == youtube) || ($remove($1,$left($strip($1),1)) == yt) || ($remove($1,$left($strip($1),1)) == youtubesearch)) {
if ($left($1,1) != /) {
if ($2 != $null) {
set $+(%,youtube.,%ticks,.msgtype) msg $active
.timerYTInputSyntax -m 1 100 echo -at 4Incorrect Syntax - Use10 $1 <search term>
elseif ((*youtube.com* iswm $1-) || (*youtu.be* iswm $1-)) {
var %i 1
while (%i <= $numtok($1-,32)) {
if ((*youtube.com* iswm $($+($,%i),2)) || (*youtu.be* iswm $($+($,%i),2))) {
if (*/playlist* iswm $($+($,%i),2)) { halt }
set $+(%,youtube.,%ticks,.url) $strip($($+($,%i),2))
var %tag $($+(%,youtube.,%ticks,.url),2)
var %tag $iif($numtok(%tag,46) > 1,$gettok(%tag,$calc($numtok(%tag,46)-1) - $numtok(%tag,46),46),%tag)
var %tag $iif($matchtok(%tag,v=,1,38),$v1,%tag)
var %tag $deltok($deltok(%tag,2,35),2,38)
if (*youtu.be* iswm %tag) { var %tag $gettok(%tag,1,63) }
set $+(%,youtube.,%ticks,.tag) $remove(%tag,com/watch?v=,youtube.,$chr(40),$chr(41),?,m.,v=,/watch?src_vid=,https://,http://,www.,/v/,youtube.com,youtu.be,youtu.be/,/watch?v=,/watch,?v=,$chr(31),#!,/)
inc %i
if (($($+(%,youtube.,%ticks,.tag),2) == %_youtube.last) || ($($+(%,youtube.,%ticks,.tag),2) == $null) || ($($+(%,youtube.,%ticks,.tag),2) == com) || (*/channel/* iswm $($+(%,youtube.,%ticks,.url),2)) || (*/user/* iswm $($+(%,youtube.,%ticks,.url),2))) {
unset $+(%,youtube.,%ticks,.*)
else {
set $+(%,youtube.,%ticks,.msgtype) $iif(%_youtube.notices == true,echo -a,msg $active)
set $+(%,youtube.,%ticks,.nick) $nick
set $+(%,youtube.,%ticks,.chan) $chan
set $+(%,youtube.,%ticks,.network) $network
#search end
#parse on
on $*:text:/youtu(.be|be.com)/Si:*: {
halt
halt
else {
inc -z $+(%,botflood.,$nick) 10
else { inc -z $+(%,botflood.,$nick) 10 }
var %i 1
var %ticks $ticks
set $+(%,youtube.,%ticks,.tag) $remove(%tag,com/watch?v=,youtube.,?,m.,v=,/watch?src_vid=,https://,http://,www.,/v/,youtube.com,youtu.be,youtu.be/,/watch?v=,/watch,?v=,$chr(31),#!,/)
inc %i
if ($chan) {
if (%_youtube.notices != true) { set $+(%,youtube.,%ticks,.msgtype) msg $chan }
else {
on $*:action:/youtu(.be|be.com)/Si:*: {
halt
halt
else {
var %i 1
var %ticks $ticks
set $+(%,youtube.,%ticks,.tag) $remove(%tag,$chr(40),$chr(41),?,m.,v=,/watch?src_vid=,https://,http://,www.,/v/,youtube.com,youtu.be,youtu.be/,/watch?v=,/watch,?v=,$chr(31),#!,/)
inc %i
set $+(%,youtube.,%ticks,.msgtype) msg $iif($chan,$v1,$nick)
else {
#parse end
on *:sockopen:youtube*: {
var %ticks $remove($sockname,youtube.)
var %x sockwrite -nt $sockname
if (($($+(%,youtube.,%ticks,.search),2) != $null) && ($($+(%,youtube.,%ticks,.round2),2) != true)) {
var %temp_search0 /youtube/v3/search?safeSearch=none&order=relevance&part=snippet&q=
%x GET $+(%temp_search0,$($+(%,youtube.,%ticks,.query),2),&maxResults=,$iif(%_youtube.limit == $null,1,%_youtube.limit),&key=,$yapi) HTTP/1.1
else {
var %temp_search1 $(/youtube/v3/videos?part=contentDetails%2Cstatistics%2Csnippet&id=,0)
var %temp_search2 &maxResults=1&fields=items $+ $chr(40) $+ $(contentDetails%2Csnippet%2Cstatistics,0) $+ $chr(41)
%x GET $+(%temp_search1,$($+(%,youtube.,%ticks,.tag),2),%temp_search2,&key=,$yapi) HTTP/1.1
%x Host: www.googleapis.com
%x $crlf
alias nohtml { return $regsubex($$1-,/^[^<]*>|<[^>]*>|<[^>]*$/g,) }
alias yinfo {
var %step1 errRemoval $gettok($1-,2-,58) errRemoval
return $replace($gettok(%step1,$+(2-,$calc($numtok(%step1,34) - 1)),34),\r\n,$chr(32),\n,$chr(32),\","))
on *:SOCKREAD:youtube*: {
if ($sockerr) { echo -a SOCKET ERROR: $sockerr | halt }
else {
var %ticks $gettok($sockname,2,46)
var %sockreader
sockread %sockreader
if ((*"title": * iswm %sockreader) && ($($+(%,youtube.,%ticks,.title),2) == $null)) {
set $+(%,youtube.,%ticks,.title) $yinfo(%sockreader)
if ($($+(%,youtube.,%ticks,.search),2) != $null) {
var %i 0
while (%i <= $numtok($($+(%,youtube.,%ticks,.search),2),32)) {
inc %i
set $+(%,youtube.,%ticks,.title) $regsubex($($+(%,youtube.,%ticks,.title),2), /\b( $gettok($($+(%,youtube.,%ticks,.search),2),%i,32) )\b/gix, $+($chr(2), \1, $chr(2)))
;Badword replacement below--useful for bots that kick on badword list. Replace or add words to censor <word,replacement>
set $+(%,youtube.,%ticks,.title) $replace($($+(%,youtube.,%ticks,.title),2),faggot,f****t,nigger,n****r)
elseif (*"videoId": * iswm %sockreader) {
var %temp $ticks
set $+(%,youtube.,%temp,.round2) true
set $+(%,youtube.,%temp,.search) $($+(%,youtube.,%ticks,.search),2)
set $+(%,youtube.,%temp,.query) $($+(%,youtube.,%ticks,.query),2)
set $+(%,youtube.,%temp,.msgtype) $($+(%,youtube.,%ticks,.msgtype),2)
set $+(%,youtube.,%temp,.tag) $yinfo(%sockreader)
sockopen -e $+(youtube.,%temp) www.googleapis.com 443
inc $+(%,youtube.,%ticks,.number)
if (%_youtube.limit == $($+(%,youtube.,%ticks,.number),2)) {
unset $+(%,youtube.,$remove($sockname,youtube.),*)
sockclose $sockname
elseif (*channelTitle": * iswm %sockreader) { set $+(%,youtube.,%ticks,.user) $yinfo(%sockreader) }
elseif (*"duration": * iswm %sockreader) {
set $+(%,youtube.,%ticks,.time) $regsubex($duration($calc($replace( $remove($yinfo(%sockreader), P, T), W, *604800+, D, *86400+, H, *3600+, M, *60+, S,*1)), 3), /^[0:]+, )
elseif (*"publishedAt": * iswm %sockreader) { set $+(%,youtube.,%ticks,.date) $gettok($yinfo(%sockreader),1,84) }
elseif ((*"description": * iswm %sockreader) && ($($+(%,youtube.,%ticks,.description),2) == $null)) {
var %wrong errRemoval ", errRemoval
var %desc $yinfo(%sockreader)
if (($gettok(%sockreader,4,34) == $null) || (%desc == %wrong)) { set $+(%,youtube.,%ticks,.description) N/A }
else { set $+(%,youtube.,%ticks,.description) $iif($numtok(%desc,32) > 10,$+($gettok(%desc,1-8,32),...),%desc) }
elseif (*"viewCount": * iswm %sockreader) { set $+(%,youtube.,%ticks,.viewcount) $bytes($yinfo(%sockreader),bd) }
elseif (*"likeCount": * iswm %sockreader) { set $+(%,youtube.,%ticks,.likes) $bytes($yinfo(%sockreader),bd) }
elseif (*"dislikeCount": * iswm %sockreader) || (($($+(%,youtube.,%ticks,.viewcount),2) != $null) && (*}* iswm %sockreader)) {
set $+(%,youtube.,%ticks,.dislikes) $bytes($yinfo(%sockreader),bd)
set %_youtube.last $($+(%,youtube.,%ticks,.tag),2)
$iif($($+(%,youtube.,%ticks,.viewcount),2) == 301,set $+(%,youtube.,%ticks,.viewcount) 301+,noop)
var %msg 1,0You0,4Tube $&
$iif($($+(%,youtube.,%ticks,.search),2) == $null,$null,10Link:14 http://youtu.be/ $+ $($+(%,youtube.,%ticks,.tag),2)) $&
10Title:14 $($+(%,youtube.,%ticks,.title),2) $&
$iif(%_youtube.noviews == true,$null,10Views:14 $($+(%,youtube.,%ticks,.viewcount),2)) $&
$iif(%_youtube.nolength == true,$null,10Length:14 $($+(%,youtube.,%ticks,.time),2)) $&
$iif(%_youtube.date == true,10Uploaded:14 $($+(%,youtube.,%ticks,.date),2),$null) $&
$iif(%_youtube.nouser == true,$null,10User:14 $($+(%,youtube.,%ticks,.user),2)) $&
$iif(%_youtube.likes == true,10Likes:14 $($+(%,youtube.,%ticks,.likes),2),$null) $&
$iif(%_youtube.dislikes == true,10Dislikes:14 $($+(%,youtube.,%ticks,.dislikes),2),$null) $&
$iif(%_youtube.description == true,10Description:14 $($+(%,youtube.,%ticks,.description),2),$null)
var %msg = $remove(%msg,$chr(9))
$($+(%,youtube.,%ticks,.msgtype),2) $iif(%_youtube.nocolor == true,$strip(%msg),%msg)
sockclose $sockname
elseif (*"totalResults": 0,* iswm %sockreader) {
var %msg 1,0You0,4Tube 10No relevant results were found. Try different search terms.
sockclose $sockname
elseif (*"items": []* iswm %sockreader) {
var %msg 1,0You0,4Tube 10This video was removed or is no longer available.
sockclose $sockname
on *:sockclose:youtube*: { unset $+(%,youtube.,$remove($sockname,youtube.),*) }
on *:start: .timerYTUpdate 1 60 yupdate
alias yupdate {
unset %youtube.* | unset %ysearch.*
;echo -atc info 12[04YouTube12] Checking for updates and clearing variables...
sockopen yupdate hawkee.com 80
on *:sockopen:yupdate: {
%x GET /snippet/8577/ HTTP/1.1
%x Host: hawkee.com
%x $crlf
on *:SOCKREAD:yupdate: {
if (*<title>* iswm %sockreader) {
var %x $remove($gettok($nohtml(%sockreader),7-,32),- mIRC)
if ($yversion != %x) {
echo -atc info 12[04YouTube12] Current: $yversion Latest: %x Status: Please check for updates at http://hawkee.com/snippet/8577/
unset %sockreader
sockclose $sockname
