Kod: Tümünü seç
on *:load: {
.echo -aq $input(Yapımcı: SaNCaK $+ $crlf $+ $crlf $+ Addon: Log Okuyucu $chr(40) $+ v5.4 $+ $chr(41) $+ $crlf $+ $crlf $+ Yapım: 17/10/2014 $+ $crlf $+ $crlf $+ Iletişim: [email protected] $+ $crlf $+ $crlf $+ Kodu Kullandığınız için Teşekkür ederim,igo,Addon: Log Okuyucu $chr(40) $+ v5.4 $+ $chr(41))
echo -a _____________________________________________________________________________________
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Add-On yükleniyor...
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Çalışan mIRC15 $version 0Sistem15 Windows $+ $os
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Coder: 15SaNCaK 0,1 E-Mail: [email protected]
echo -a 4,1[00,01 SaNCaK 4,1] 15,1 Copyright 12©15 1999-2017
echo -a ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
on *:unload: {
.echo -aq $input(Author: SaNCaK $+ $crlf $+ $crlf $+ Addon: Log Okuyucu $chr(40) $+ v5.4 $+ $chr(41) $+ $crlf $+ $crlf $+ Released at: 17/10/2016 $+ $crlf $+ $crlf $+ Contact: [email protected] $+ $crlf $+ $crlf $+ Unloading...,igo,Addon: Log Okuyucu $chr(40) $+ v5.4 $+ $chr(41))
menu menubar,channel {
Log Okuyucu: { dialog -m blog blog }
dialog blog {
title "Log Okuyucu"
size 380 257 385 260
box "", 8, 1 -2 382 260
list 1, 2 6 212 250, size
box "Ara:", 2, 215 -2 168 116, flat
check "Nick:", 3, 222 15 53 13, flat
edit "", 4, 221 28 115 23, multi return
text "for", 23, 49 60 21 13, hide
text ".log", 5, 338 36 25 17
check "Yazılarda Ara:", 6, 222 55 103 13, flat
edit "", 7, 221 68 145 23, multi return
box "Info:", 9, 215 106 168 102
text "Kayıt:", 10, 222 122 53 13
text "Göster", 25, 71 73 27 13, hide
text "Son Değişiklik:", 11, 222 147 113 13
text "Add-on", 21, 21 33 38 14, hide
text "Boyut:", 12, 220 171 101 13
box "Tercih:", 13, 215 200 168 58
text "Rc", 24, 56 72 15 13, hide
text "", 14, 222 135 153 13
text "", 15, 222 159 151 13
text "", 16, 222 185 151 13
button "Oku", 17, 222 219 45 21, flat
button "Sil", 18, 269 219 45 21, flat
button "Kapat", 19, 316 219 45 21, ok flat
text "Feito", 22, 41 47 26 14, hide
button "Ara", 26, 306 91 75 21, flat
on *:dialog:blog:sclick:17:{ window @log | loadbuf -rp @log $+(",%blog.dir,$$did(blog,1,$did(blog,1).sel).seltext,") }
on *:dialog:blog:sclick:18:{ .remove $+(",%blog.dir,$$did(blog,1,$did(blog,1).sel).seltext,") | did -d blog 1 $did(blog,1).sel }
on *:dialog:blog:sclick:26:{
if ($did(3).state == 1) || ($did(6).state == 1) {
if ($did(3).state == 1) {
set %blog.nome $+($as1($did(blog,4)).log)
else {
set %blog.nome *.log
if ($did(6).state == 1) {
set %blog.text $as1($did(blog,7))
else {
set %blog.text *
blog.findfile1
halt
echo -a 0,1 Arama yapılması için seçenek kutucugunu tıklayınız
on *:dialog:blog:init:*:{
set %blog.dir $logdir
blog.finddir
on *:dialog:blog:sclick:1:{
if (*.log iswm $did(blog,1,$did(blog,1).sel).seltext) {
did -r blog 14,15,16
var %blog.arquivo $+(%blog.dir,$did(blog,1,$did(blog,1).sel).seltext)
did -a blog 14 $asctime($file(%blog.arquivo).ctime)
did -a blog 15 $asctime($file(%blog.arquivo).mtime)
did -a blog 16 $bytes($file(%blog.arquivo),k).suf
on *:dialog:blog:dclick:1:{
if (*.log !iswm $did(blog,1,$did(blog,1).sel).seltext) {
if ($left($right($did(blog,1,$did(blog,1).sel).seltext,-1),-1) == ..) && ($did(blog,1).sel == 1) {
if (!%blog.busca) {
var %blog1 $wildtok(%blog.dir,*,0,92)
var %blog3 [ $+(1-,[ [ $calc(%blog1 - 1) ] ]) ]
var %blog2 $+($gettok(%blog.dir,[ [ %blog3 ] ],92),\)
set %blog.dir [ %blog2 ]
did -r blog 1
blog.finddir
halt
did -r blog 1
unset %blog.busca
blog.finddir
halt
set %blog.dir $+(%blog.dir,$left($right($did(blog,1,$did(blog,1).sel).seltext,-1),-1),\)
did -r blog 1
blog.finddir
halt
window @log
loadbuf -rp @log $+(%blog.dir,$did(blog,1,$did(blog,1).sel).seltext)
alias as1 {
if ($1) {
if ($left($1,1) == *) {
var %r $1-
goto 2
var %r $+(*,$1-)
:2
if ($right($1-,1) == *) {
var %r [ %r ]
goto 3
var %r $+(%r,*)
:3
return %r
return *
alias blog.findfile1 {
did -r blog 1
window -hs @logview
window -hs @logview1
set %blog 0
:comeco
inc %blog
tokenize 32 $findfile(%blog.dir,%blog.nome,%blog)
var %blog1 $wildtok($1-,*,0,92)
var %blog3 $+(1-,[ [ $calc(%blog1 - 1) ] ])
var %blog2 $+($gettok($1-,[ [ %blog3 ] ],92),\)
if (%blog2) {
if (%blog2 == %blog.dir) && (%blog.text != *) {
filter -p $+(",$1-,") @logview1 %blog.text
if ($filtered) {
did -r blog 1
aline @logview $remove($1,%blog.dir)
goto comeco
goto comeco
if (%blog2 == %blog.dir) {
goto comeco
if ($line(@logview,1)) {
set %blog 1
did -a blog 1 [..]
while ($line(@logview,%blog)) {
did -a blog 1 $line(@logview,%blog)
inc %blog
else {
did -a blog 1 [..]
did -a blog 1 No file was found
set %blog.busca CURIOSO!!!
window -c @logview1
window -c @logview
alias blog.finddir {
var %blog 0
if (%blog.dir != $logdir) {
did -a blog 1 [..]
:comeco
inc %blog
tokenize 32 $finddir(%blog.dir,*,%blog)
did -a blog 1 $+([,$remove($1-,%blog.dir),])
goto comeco
blog.findfile
alias blog.findfile {
window -sh @logview
var %blog 0
:comeco
inc %blog
tokenize 32 $findfile(%blog.dir,*.log,%blog)
aline @logview $remove($1-,%blog.dir)
goto comeco
var %blog 1
inc %blog
window -c @logview
