Atheme MemoServ Komutları
Bu bölümde IrC hakkında paylaşım ve sorunlarınızı anlatabilirsiniz
Kullanıcı avatarı
Immortal
Admin
Admin
Kayıt: 01 Eyl 2009, 06:05
Mesaj gönderen Immortal »
MemoServ
DELETE
DELETE allows you to delete memos from your inbox. You can delete all memos with the ALL parameter, all read memos with the OLD parameter, or specify a memo number.
You can obtain a memo number by using the LIST command. Once you delete a memo, the numbers of all subsequent memos will change.
You can also SEND, READ, LIST and FORWARD memos.
Syntax: DELETE ALL|OLD|<memo number>
Examples:
/msg MemoServ DELETE OLD
/msg MemoServ DELETE 1
FORWARD
FORWARD allows you to forward a memo to another account. Useful for a variety of reasons.
You can also SEND, DELETE, LIST or READ memos.
Syntax: FORWARD <user|nick> <memo number>
Examples:
/msg MemoServ FORWARD kog 1
IGNORE
IGNORE allows you to ignore memos from another user. Possible reasons include inbox spamming, annoying users, bots that have figured out how to register etc.
You can add up to 40 users to your ignore list
Syntax: IGNORE ADD|DEL|LIST|CLEAR <account>
Examples:
/msg MemoServ IGNORE ADD kog
/msg MemoServ IGNORE DEL kog
/msg MemoServ IGNORE LIST
/msg MemoServ IGNORE CLEAR
LIST
LIST shows you your memos in your inbox, including who sent them and when. To read a memo, use the READ command. You can also DELETE or FORWARD a memo.
Syntax: LIST
Examples:
/msg MemoServ LIST
READ
READ allows you to read a memo that another user has sent you. You can either read a memo by number or read your new memos.
Syntax: READ <memo number>
Syntax: READ NEW
Examples:
/msg MemoServ READ 1
SEND
SEND allows you to send a memo to a nickname that is offline at the moment. When they come online they will be told they have messages waiting for them and will have an opportunity to read your memo.
Your memo cannot be more than 300 characters.
Syntax: SEND <user|nick> text
Examples:
/msg MemoServ SEND Kog pay your bills
SENDGROUP
SENDGROUP allows you to send a memo to all members of a group who have the +m flag.
Syntax: SENDGROUP <!group> <text>
Examples:
/msg MemoServ SENDGROUP !opers beware of badguy
SENDOPS
SENDOPS allows you to send a memo to all ops on a channel. Only users allowed to view the access list can do this.
Syntax: SENDOPS <#channel> <text>
Examples:
/msg MemoServ SENDOPS #chat beware of badguy
AlwayS.BelievE.In.YouR.HearT.No.MatteR.WhaT
